FieldPoint Family
I am losing communication to the FP-3000 every few days.
I am communicating to the FP-3000 via OPC. Every few days I lose communication to the FP-3000. The ready light has turned off. Rebooting the unit corrects the problem. Does anyone have any ideas?
(2,979 Views)
It sounds like the problem of I/O module. Make sure the I/O module is firmly seated, the terminal base is firmly attached to the terminal base on its left.
You may look for bent pins on the bottom of the module or between terminal bases (don't forget power down the bank before removing terminal bases).
You can also send e-mail to "fieldbus.support@ni.com" for further support.
(2,979 Views)
