It sounds like the problem of I/O module. Make sure the I/O module is firmly seated, the terminal base is firmly attached to the terminal base on its left.
You may look for bent pins on the bottom of the module or between terminal bases (don't forget power down the bank before removing terminal bases).
You can also send e-mail to "fieldbus.support@ni.com" for further support.
