02-13-2003 03:20 AM
02-14-2003 08:47 AM
05-13-2005 11:48 AM
05-13-2005
03:10 PM
- last edited on
03-10-2025
02:09 PM
by
Content Cleaner
I think that you can use any size Compact Flash in a cFP controller (definitely anything smaller than 512 MB).
-I'm currently emailing the PSE to check on this-
The real problem you'll run into is that you cannot get Compact Flash in sizes over about 4GB.
Amazon Flash > 4GB
You may want to try to implement a double-buffer-type system that looks for a network connection and then sends the data, then stores until a connection is present again. However, if you overflow, you'll lose data.
As vg said he could store that much information in a PXI controller (NI PXI-8187 RT). May be a bit of overkill, but it could store that much data.
05-13-2005 04:37 PM
