FieldPoint Family
I need help with error code 32812:
Hi. I am trying to read in some voltages using FP-AI-112. A while ago, I developed a Labview program to do that, and it worked fine. Now, I'm going back and using it again, and I keep getting the error code 32812: "the specified tag name is not found." I have checked and rechecked my tag name in Fieldpoint Explorer over and over again, and I swear that the tag name in my program is identical to the one in Fieldpoint Explorer. Please help. Thanks.
(3,591 Views)
Which version of FP Explorer are you using? Did check the configuration of the IAK file itself?
You can read the following to get more information:
http://digital.ni.com/public.nsf/websearch/02EB73D02715981A8625682B00774F8F?OpenDocument
Hope that this helps. Good luck!
Chin Pei
(3,585 Views)
