FieldPoint Family
Is LabView Real-time for Compact FieldPoint necessary ?
Hello !
Is LabView Real-time for Compact FieldPoint (cFP) necessary ?
(in german: Ist für die Nutzung von Compact FieldPoint LabView Real-time notwendig ?)
Thank you.
Bye, Ouafa
(7,718 Views)
Yes, you will need LabVIEW Real-time to run applications on the cFP.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(7,717 Views)
Not necessarily.
If you are using a controller module such as the cFP-2220 to run a program on, then yes.
But if you are using a network module such as a cFP-1804, then the program runs on a Windows PC and the real time module should not be necessary.
(7,709 Views)
Hi !
Thank you for the responses. :womanhappy:
I don't want to use the stand-alone embedded-controller of the cFP-2220 but rather the Pc with LabView for data logging and graphics (using Ethernet).
Is LabView Real-time for my application necessary ?
Bye, Ouafa
(7,692 Views)
Accepted by katsumi
if you just wanna use Labview for logging and graphics (using Ethernet) AND you do NOT use a Real-Time cFP-Controller then you do not need Labview Real Time.
E.g. if you use NI cFP-1804 - Ethernet/Serial Interface for Compact FieldPoint.
(https://www.ni.com/en-us/support/model.cfp-1804.html)
If you are using a Real Time Controller than you will NEED Labview Real-Time.
You cannot work without it!!!
Best regards
Dippi
(7,682 Views)
