FieldPoint Family
Is there a Fieldpoint Find Devices Vi that I can use programatically?
Hello All,
I'm trying to build a program using Fieldpoint I/O that will run in my PC and will work with several different Fieldpoint configurations.
Is there a Fieldpoint Find Devices Vi that I can use programatically?  (Like the one built into MAX)
It would allow me to only configure tags for only what is actually connected.
Using LV7.0 @ Win2K.
Mike
(3,847 Views)
Hi Mike!
   What modules are you working with?
   There're interesting examples dealing  with find devices, take a look at "Find FP-100x devices (VISA).vi",  this is useful to describe an fp-1000/1001 module with related I/O modules connected.
   I don't know how  to do it in  ethernet, to find, for example, fp-20xx modules....
   Hope it helps!
graziano
(3,832 Views)
Mike,
There is not a VI that will allow you to find and use FieldPoint devices on the network programmatically. An IAK file must first be created (in MAX) to use it in LabVIEW.
Michael P
(3,827 Views)
Michael,
I found a vi (in LV) called "Get FP Channel Info.vi".
When I enter the IP and module addresses, it returns the Module Name and something called an "MIS String".
I'm guessing I can use that data to decode the module...can you help with that?
Also, when I try to open the Block Diagram it tells me it's password protected.  So I can't see exactly what it's doing.
Can you provide the password?
Also, since I have two TB-10's in my system, I'll need to know how to decode all of the I/O modules that are available for those.
Mike
(3,811 Views)
I replied to this post by email. The inner workings of the FieldPoint driver are not supplied to customers, which is why that subVI's block diagram is password protected.
Michael P
(3,804 Views)
