FieldPoint Family
Is there any encoder/decoder modules with FP
we are using field points along with a pxi system in our application i wanted to know whether any possibility of encoder and decoder is there along with field points
(3,283 Views)
I am assuming you have a encoder signal to read in, if that is the case, consider the FP-QUAD-510, that is a module for Quadradure Encoder, check the info here :
http://sine.ni.com/apps/we/nioc.vp?cid=4313〈=US
I hope it helps
Andre Oliveira
(3,283 Views)
