FieldPoint Family
pH measurement using FieldPoint and LabVIEW6.1
I am using FP-AI-110 and FP-AO-210 to acquire data from pH probe into my program. When I connect the pH probe with the system and run the program, it gives me error message that specific tag not found as I am using the proper name for every field. As my pH probe is already calibrated, I am not putting code for calibration.
(3,354 Views)
FieldPoint requires an exact match on the name with what is in the .IAK file.
Check the IAK file you are using.
Check upper-case/lower-case
Check for extra "space" characters.
Ben
(3,354 Views)
Hi Ben! Thanks for your reply. I have already checked all the things which you have suggested. Still I am getting the same error. I am really new to LabVIEw but I have already checked about what have you suggeted for my problem
(3,354 Views)
