FieldPoint Family
Missing linear fit VI, lvanlys.dll FP-2000 won't run on desktop.
Do you have other controller you can try it on?  I only ask because the FP-2000 only has 24 MB user accesible.  Maybe it is the size of your program.   Anyone else have a FP-2000 to try the Math Analysis VIs on?
"If you want to succeed... Architect" - The Specialist
Message 11 of 17
(4,739 Views)
Hi Bill,
Can you post the program that you are trying to run here? I will need all the files (people often forget to post sub vis, projects etc.). I am going to test it on a machine here.
Warm regards,
Karunya R
Message 12 of 17
(4,725 Views)
What software do you have installed on it (screen shot would be great)? And are you able to run a simple Vi on it?
Warm regards,
Karunya R
Message 13 of 17
(4,719 Views)
Hi Karunya,
I reformated one of my FP-2000 controllers, started with a clean project and the only VI I tried to run was the polynomial fit VI.  It wouldn't load on the controller.  So, here is where I see the issue:  Right now, the basic FP-2000 controller doesn't have enough memory to load the complete advanced math palette and I will have to build my own polonomial fit code.  Unless there is a way to load only the VIs that are necessary to run my code.
No, I don't have another controller with more memory.  Currently I only have 7 - FP-2000 controllers.
Let me know if I can clarify anything else.
Bill
Message 14 of 17
(4,719 Views)
I install the LV 8.5.1 minimal software on all of my controllers.
-Bill
Message 15 of 17
(4,717 Views)
Bill,
If it is a memory issue, unfortunately nothing can be done about it. I am sorry about that!
Warm regards,
Karunya R
Message 16 of 17
(4,683 Views)
I am running across a similar LabVIEW error message and was wondering if this was a hardware issue as well? My assumption is software between Windows 7 computer I built the program on and the Windows XP system I'm trying to use it on.
Missing external function lvanlys.dll:RMS_head:C in VI NI_AALPro.lvlib:RMS (DBL).vi
Thanks for any help on this particular issue because I couldn't find a solution yet.
Message 17 of 17
(3,516 Views)
