FieldPoint Family
Multiple applications using same fieldpoint
I have built several applications using the same fieldpoint .iak file. They are built as stand alone applications to use on a single computer.
So far they work fine. My question is that when I am running one application and try running another, the first stops.
I am using different channels on the field point module for each application, but they both use the same .iak file.
Is there a way to build these applications so that several will run on the same module (different channel) at the same time if needed?
Jim
(3,761 Views)
Jim,
I don't now if your approach can work (e.g. the Fieldpoint driver allow it), however my way to solve that problem:
Write one vi that will do the Fieldpoint handling (Open,close,IO) and that run in its own treat(FPhandle.vi).
For communication you can use VI-Server (to start that vi and read a handle) and named queues for the data transfer.
A new.vi will load the FPHandle.vi with vi-server and look at an status-indicator telling if it's already running/FP-device opened etc.. If not: run it in the background
FPhandle.vi listen to a named queue ('FPhandlecommand') with a data type (cluster) including the string (name) for your return-queue ('new-return') and a command string or better a strict type defined enumerated (nice if you want to add new commands later)
You can/should collect a list of return-queue names and remove them from that list if they send you a FP-close command. When the list is empty you can really close the FP connection.
Greetings from Germany
Henrik
LV since v3.1
(3,754 Views)
Would using two seperate .iak files work when I use two different programs to access two different channels (at the same time)???
Jim
(3,737 Views)
