FieldPoint Family
Multiplot xy graph
I am writing an application with 2-channel XY Graph plot, using while-loop and Insert Into Array function. One-channel version works perfectly, but with two I am in trouble. In the attachment you can find the trial version with Rundom numbers plotting. Could you please help me to find a right way?
Thank you in advance,
Armen
(4,241 Views)
It appears that you are combining your 2 points, 1 for each plot, and then adding them to the end of a single array that makes up the x-y graph.  Each iteration of your loop, 2 points are added to a single plot, 1 point from the larger random number and 1 point from the smaller random number.
You may want to consider a shift register for each array where you append the new points to their respective arrays, then combine the 2 arrays into 1 larger multi-dimensional array that gets fed into the XY graph.
(4,225 Views)
Could I get an example of such a vi.
(3,571 Views)
