FieldPoint Family
On Cold Boot Up of FP2010 Locks up if Accessing Via Ethernet Port
Ok The FP2010 is powered up and if a client attempts to communicate via ethernet to the application that is launched on startup the unit goes off in the weeds and appears to stop the startup process.  This happens with any client app or even IE accessing the VI web page.  Any reason for this? Is there a fix or way around it?
TIA,
David
(3,108 Views)
Hi David,
Could you try running a shipping example program on the FP 2010?  Please do this and let me know if you run into the same problem.
Hal L.
(3,095 Views)
