FieldPoint Family
How do I attach an .iak file when using application buider?
I want to create an .exe file using application builder to run on a computer without Labview. I need to communicate with a FP1000 controller and I/O. How do I get the ".iak" info to work with the exe file or do I have to install Fieldpoint or MAX  on the computer running the program?
John
(3,128 Views)
JShaw,
You will need to install the Fieldpoint driver onto the remote computer (MAX should come with the driver).  Once you have done this, use the .iak file from your developement system.
Lorne Hengst
Application Engineer
(3,119 Views)
