FieldPoint Family
Open different channels at the same time in a NI-FP-403
I am using a NI-Field Point 403 to power a series of solenoid valves. Depeding on the input that I receive from a digital pressure transducer I need to power certain valves at the same time. At this point I am using a VI where I need to select one channel at a time to power a single solenoid valve once the VI is running. What would I need to do to power several channels at one time?
Jordi
Boise State University
(3,480 Views)
Hello Jordi,
Are you using LabVIEW?  If so, there is an example in the NI Example Finder (Help >> Find Examples) called Digital Output.  It is found in the Hardware Input and Output >> Fieldpoint >> Getting Started section.  It uses the "All Channels" item to write a digital out value to multiple channels at the same time.
If this is not the sort of answer you are looking for, please give us more information about what your program does and we will be happy to help.
Laura
(3,472 Views)
It worked. Thanks!
(3,463 Views)
