FieldPoint Family
Plotting using UI activeX graph control
how can i plot the graph by extracting x and y data from the database i.e from data already stored in data base which i retrieve by writing queries
(3,343 Views)
Hello -
Before I can find you an answer, I need some more information:
1. Are you using LabVIEW or another programming language? What version are you using?
2. Are you using the Enterprise Connectivity Toolkit or another toolkit for LabVIEW?
3. What type of database are you querying?
4. Are you trying to use the ActiveX container in LabVIEW to plot a graph in Excel or are you using another application?
If you are using LabVIEW and a toolkit, you might want to check out the Toolsets Development Library which has example code, technical presentations and tutorials.
Have a great day!
Becky B.
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
(3,343 Views)
