FieldPoint Family
simulink with compact field point.
I have an existing labview application that I am moving to compact fieldpoint hardware. The current application uses the simulation toolkit vis together with a .dll that was generated from Matlab/simulink. The simulation runs and provides data that a control system needs to follow. Can I get the simulink executable in a form that can run on the compact fieldpoint. I can get the vi with the simulink model code in it to run in Labview with it being dowloaded to the compact fieldpoint hardware as the target. I get no errors except that the simulation does not give the proper answers when it runs. I get no errors reported and the rest of the labview program runs properly (ie pump contollers PID) at that time.
Am I missing something?
(3,368 Views)
Hi James,
Yes, you can run your Simulink model from LabVIEW on CompactFieldPoint. I would suggest going through the Manual starting at page 21 that discusses what must be done to deploy your Simulink model. The following tutorial, How to Create Simulation DLL's for LabVIEW in Simulink also discusses how this can be done.
Please post a reply if you still have questions.
Kristi H
(3,368 Views)
