Rascal,
What do you mean by this question and what are you trying to accomplish?
The IAK file is used on host computers and contains channel name, communication parameters and channel settings. The full IAK file is never downloaded into FieldPoint controllers. With FP-20XX controllers, a subset containing the channel names is downloaded into the module. With all controllers, the channel configuration information is saved into non-volatile memory (this does not include channel naming information which is only relevant for the FP-20XX series).
Using the FP Open.vi, you can specify which IAK file to use on the host machine. However, in switching between IAK files, you are only switching the communication parameters and/or channel names. Any differences in
IO configuration for channels that exist in both IAK files will not be applied to the IO channels which may result in improper readings.
Aaron
LabVIEW Champion, CLA, CPI
