I am using a cFP-2020 RT controller with 2 modules, AI-110 and
PWM-520. It is running a fairly straightforward PID loop, with 5
inputs and 2 outputs.
Regarding boot time, I believe that approx 45 seconds is the minimum
boot time even if no startup program is present. Why is this so
long? Other PLC and control devices I have used in the past offer
MUCH better boot times: I can't recall seeing anything even
approaching 10 seconds, even for large-point-count PLCs. I
believe NI needs to improve this drastically; perhaps by offering
a boot mode that can launch much faster if certain conditions are met
by the programmer.
Secondly, for every Fieldpoint tag I add to my application, it adds
about 5 seconds to initialize each of these tags. Is there a way
to optimize this? I have already defined the "All" channel the
way I need it in order to cut down on this initialization time.
Is there something else I can do?
David Moerman
TruView Technology Integration Ltd.
