FieldPoint Family
Read file from real time target
How can I read with PC-based LabVIEW from a file that is on my RT-target, eg. a FP-2010 module?
(3,212 Views)
I don't think you can do that.
What you can do is either find FTP VIs and copy the file to the computer or have a small program on the FP which will read the file and send the data to the PC using a TCP connection. You can see TCP examples by searching for TCP in the example finder. You can also try using the RT communication wizard from the Tools menu.
___________________
Try to take over the world!
(3,208 Views)
