FieldPoint Family
Retrieving cFP's IP address
From my embedded LabVIEW, I would like to retrieve the IP address of the cFP controller it is running on.  How can I do this?
I can easily do this from my Host by using the Ping Controllers.VI.  But I would like to do this on the RT target (Ping Controllers.VI did not work -- timed out -- when embedded).  Something similar to the IPCONFIG command, but for RT, would work.
Thanks in advance!
-Khalid
(3,300 Views)
Another way of doing this on a PC is using String to IP followed by IP to String (both from the TCP palette) with Dot Notation set to True.
I can't test this on a FP at the moment, but I think it will work.
___________________
Try to take over the world!
(3,296 Views)
Thanks tst; that works great!
-Khalid
(3,285 Views)
