FieldPoint Family
Repeated blue screen crash on 2 seperate Dell Optiplex 745 while running LV8.2
I am getting repeated "blue screen" crashes on 2 seperate Dell Optiplex 745's running differnet LV 8.2 code - one controlling cFP18xx controllers the other controlling a USB Multifunction card. The blue screen error message is the same on both computers - "endless loop error in file "ati2dvag". The LV 8.2 code was recently transfered to these computers from older model Dell's and HP systems, running LV 8.2 with no errors. Can you help me? Is there some incompatability between new Dell systems and LV 8.2? And if so, is there a fix? Thanks for your help!!!!
(8,446 Views)
Judging by the ati portion of the filename, sounds like a graphics driver issue. Indeed it is:
http://www.google.com/search?hl=en&q=%22ati2dvag%22&btnG=Search
You may want to try updating the driver to the latest version.
(8,438 Views)
I was unable to find any record of this error being related to LabVIEW or the DAQ drivers.  Judging from the information available on the internet there is not one cause of the error and I suggest following Analogkid's advice to reinstall the driver to see if that helps.
Eric A.
Distributed I/O Product Support Engineer
(8,429 Views)
