08-26-2008 01:14 AM
We know that we can set the following
The input ranges for voltage signals are 0–1 V, 0–5 V, 0–10 V,
±60 mV, ±300 mV, ±1 V, ±5 V, and ±10 V. voltage ranges in cFP-AI110 module using Measurement and Automation Explorer.
Would like to know if the same is possible using Labview 8.5.1
Naru
08-26-2008 06:52 AM
Naru,
You should be able to do this. Look at the Configure Range.vi. In release 8.2 it is located at Measurement I/O>>FieldPoint>>Advanced>>Ethernet Advanced.
