FieldPoint Family
Setting the cFP-AI-110 Voltage/Current Range through Labview
We know that we can set the following
The input ranges for voltage signals are 0–1 V, 0–5 V, 0–10 V,
±60 mV, ±300 mV, ±1 V, ±5 V, and ±10 V. voltage ranges in cFP-AI110 module using Measurement and Automation Explorer.
Would like to know if the same is possible using Labview 8.5.1
 Naru
(6,333 Views)
Naru,
You should be able to do this.  Look at the Configure Range.vi.  In release 8.2 it is located at Measurement I/O>>FieldPoint>>Advanced>>Ethernet Advanced.
(6,326 Views)
