09-24-2007 08:58 AM
09-25-2007
11:20 AM
- last edited on
04-07-2026
10:35 AM
by
Content Cleaner
Hi Wynn,
Do you have a firewall installed on your host computer? If so, it might be the culprit to this issue. Disabling the Windows Firewall temporarily would be a quick fix. If you want to keep the firewall enabled, follow these steps to unblock NI's Shared Variable/Tag software.
In general, your error indicates that the read or write could not be completed because the variable could not be found in the Shared Variable Engine. It typically occurs if the library containing the variable was just deployed and the read or write operation took place before the variable became available in the system. Thus, when your VI first starts up you can ignore this error.
09-25-2007 03:09 PM
09-26-2007 12:12 PM
Hi Wynn,
I like where you're going with this. If there is some sort of routine network maintence, it may be disabling Shared Variable Engine. Thus, I think disconnecting your computer from the network is a good troubleshooting idea. If anything, it will help reduce the number of culprits to this issue.
I look forward to hearing from you with the outcome.
Until then,
Emilie K. | Applications Engineer | National Instruments
01-06-2016
02:54 PM
- last edited on
04-07-2026
10:34 AM
by
Content Cleaner
I got problems using MyRio with shared variables, I could read but not write shared variables to myRIO, so I followed the spteps on this link and nothing changed, so I found that only disabling my Internet connection I could write SV to myRIO, is there a way to do that without disabling my Internet connection? Thaks a lot!!
Regards
01-07-2016
11:50 AM
- last edited on
04-07-2026
10:34 AM
by
Content Cleaner
Hi Conejo55,
The original post is under the FieldPoint Family category.You should post this as a new thread in the Academic Hardware Products section that describes your situation better so that more people who are better versed with myRIO and shared variables will see it.
In the meantime, here is some background information on shared variables:
https://www.ni.com/en/support/documentation/supplemental/06/using-the-labview-shared-variable.html
