FieldPoint Family
bad quality received from network module FP-1600
Got FP-1600 on Lookout 6.7 running OK till few days ago when I got this message under alarms:< bad quality received from network module>
What/how can I configure and save the configuration? In MAX when I try to go to configuration I get an error attached.
Please advise, thank you
(6,331 Views)
Hi 1st.DanO,
Is the status light flashing at all? If so, how many times?
Lauren
(6,308 Views)
No flashing, is OFF. Please see attached. Thank you
(6,300 Views)
Hi 1st.DanO,
You can try resetting the configuration data in NI MAX, or reinstalling NI MAX. It's possible that the MAX software or connection is corrupted. I would also ensure that you have the correct IP address set.
Lauren
(6,282 Views)
