FieldPoint Family
Verson conflicts between Host labview and RT engine
Hi.
I got some problems with the connection to the fieldpoint when I try to deploy my a VI to the fieldpoint. The connection with the fieldpoint (cFP-2120) works fine from MAX, and the program also sends/receive data to the fieldpoint when they run from the PC. I use LabView 8.0 and he Real-Time module that followed it. When I try to deploy a VI or the whole part of the project that shall run on the fieldpoint the message "Verson conflics between host labview and RT engine" appers. this message also appers when i build a small test program. Are there any thing I have to do to make this work?
thanks for the help
makaveli
(4,450 Views)
makaveli,
Version of LabView Real-Time must match between host and target.  You can use MAX to compare versions and update as needed.
centerbolt
(4,435 Views)
In MAX i find under Software --> LabView --> Real-Time, verson 8.0 for the host.
Under Fieldpoint --> Software --> I find LabView RT verson 8.0.1, is this a problem, or have I looked at the wrong place?
(4,425 Views)
(4,426 Views)
That's the problem.  You need to load LabView RT 8.0.1 on your pc.  If I remember correctly, you can have multiple versions of RT loaded on your pc at the same time.
That should take care of your problem.
(4,421 Views)
