FieldPoint Family
Where can I find informations on fieldpoint reliability?
Hallo,
   I need documentation about fieldpoint reliability.  I mean, how does the network module tests that every I/O module is wortking properly? Can I insert new modules while the pre-existing system is running an application?  And if so, how can I recognise new modules, and configure them?????
thanks!!!!
graziano
(3,257 Views)
Hi, the fp modules (network and I/O modules) are installed, configured and tested from MAX (Measurement & Automation) environment (see the following link): FieldPoint Installation/Configuration http://www.ni.com/support/fieldpoint/fpenet.htm then in the http://sine.ni.com/manuals/ you can download the manual of your module in which there is explained how to configure and test it. For more documentations see the fielponint main page: http://www.ni.com/support/fpsupp.htm Can I insert new modules while the pre-existing system is running an application? And if so, how can I recognise new modules, and configure them????? you can substitute/replace a module I/O in a fp system, because the I/O modules are hot Pnp. But if yon have to substitute the network module or add a newer fp I/O module you have to power off the system and then reconfigure it from MAX. Hope this help you Best regards AmbuA
(3,243 Views)
Thanks!
   It helps...
graziano
(3,209 Views)
