FieldPoint Family
How can I change properties of individual array elements?
I am using Fieldpoint TC-120 modules for temperature data.  I am displaying that data in an 1 x 8 array.  I am implementing an alarm that compares each value of the array against a high temp limit and a low temp limit.  I would like for the alarm to make the appropriate element of the array blink when the value is outside the alarm limits.  Is it possible to set the blink property for individual elements of my front panel array?
(3,065 Views)
I don't think you can affect the display properties of individual array elements.  What you can however do is use a Table indicator instead.  Table allows you to change individual cells' colours (thus getting the blinking effect) using property nodes.
-Khalid
(3,060 Views)
