FieldPoint Family
Why am I getting Error 33494?
While I am running my application, I am getting Error 33494 occured at The module is Empty,possible reasons: The module does not exist. what could be the reason and what should I do to overcome it?
(3,094 Views)
Suna,
Error code 33494 primarily occurs when using Dual Channel modules. It indicates that you tried to read from or write to a dual channel module that does not exist. Possible reasons:
1) You are trying to read/write a channel that does not have a module in the FP-TB-10.
2) The Dual Channel module has not been fully inserted and locked into place.
3) The Dual Channel module is damaged in some way such as bent pins.
Aaron
LabVIEW Champion, CLA, CPI
(3,094 Views)
