FieldPoint Family
Why does my FP-AI-200 module output a reversed current
When using measurement and automation explorer to test an FP-AI-200 module I get reversed output. For example if I set the output current to 20mA I get an actual output current of 0mA and vice versa.
(3,394 Views)
Oops...FP-AO-200!
(3,394 Views)
I would start by checking if the behavior is seen in all the channels.
Make sure you have your wiring correct and if it keeps showing this behavior call National Instruments for support on this one, there should be no reason for the behavior you described there.
Best Regards
Andre Oliveira
(3,394 Views)
