FieldPoint Family
Can I change the voltage range of an analog input (FP-AI-102 Input Module) in LabView?
in my application I use a FieldPoint AI-102 analog input module which is controlled by LabView. Is it possible to change the voltage range of the inputs in Labview or can I only change them in the "Measurement and Automation Explorer"?
(3,262 Views)
See
FieldPoint>>>Ethernet Configuration>>>Configure Range
if you have a ethernet based FP network module.
Ben
(3,262 Views)
