Home
Community
Discussion Forums
Most Active Hardware Boards
FieldPoint Family
Topic
FieldPoint Family
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can I change the voltage range of an analog input (FP-AI-102 Input Module) in LabView?
Michi M.
11-26-2003
03:01 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
in my application I use a FieldPoint AI-102 analog input module which is controlled by LabView. Is it possible to change the voltage range of the inputs in Labview or can I only change them in the "Measurement and Automation Explorer"?
0
Kudos
Message
1
of 2
(3,263 Views)
Reply
Re: Can I change the voltage range of an analog input (FP-AI-102 Input Module) in LabView?
Ben
Knight of NI
11-26-2003
09:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
See
FieldPoint>>>Ethernet Configuration>>>Configure Range
if you have a ethernet based FP network module.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 2
(3,263 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
