FieldPoint Family
Why my new cFP-TC-120 can not work with my VB6 application for FP-TC-120 ?
I just purchased cFP-TC-120 system. When I using with my own developed VB6 application for FP-TC120 which current running in my production floor. Seem the compact field point has not recongnize the command sent via RS232 with orginal FP-TC-120 command set.
(6,258 Views)
Hi Thee,
What kind of controller/network module did you purchase?  What is the command that you are sending to the cFP-TC-120?  If you are using a cFP-1804 or 1808 network module and programming with Optomux, these modules only support the extended commands and Power Up Clear set.  You can see the Optomux programming reference here (http://digital.ni.com/manuals.nsf/websearch/A62558E5BDED8486862573460055DF12 ).
Message Edited by Smootastic on 04-21-2009 02:00 PM
(6,242 Views)
