FieldPoint Family
cFP-180x firmware versions
Tq for your promtp reply.But i think there is nothing wrong with the software installation. It working well before this. Last day after i reset the ip address and put the same ip again then the ready LED CFP I/O module turn to ON and function as normally until now. I just need to know the technical reason why this problem occured. Maybe you have receive the same problem like this before. I am worried if it will happen again and so i can give the same reason as yours to my client. Actually i used this NI to intergrated with our system. Just to grab the input output data only. TQ
Message 11 of 20
(3,806 Views)
Good morning ikramic,
The "ready" light on the modules will not light if the controller enters a bad state or boots improperly. To change the IP address you most likely had to reboot the controller, which is probably what solved the problem. If it occurs again just try resetting the controller.
Jesse Dennis
Engineer
INTP
Message 12 of 20
(3,782 Views)
what cause the controller boots improperly?is it because of the surround enviroment? or the controller itself have a bug in the operating system?
Message 13 of 20
(3,774 Views)
Hi ikramic,
I could be either, but it most likely was a surrounding condition. If you can reproduce a crash we can isolate the problem and fix it. However, user programs, bad power supplies and any other number of problems could make the controller enter a bad state.
Jesse Dennis
Engineer
INTP
Message 14 of 20
(3,762 Views)
Actually i've tried to shut off and on the CFP power so many times but the problem not occur.
one question, if i use the reset button (not dip switch) does the IP will be deleted also?
Message 15 of 20
(3,757 Views)
Good morning Ikramic,
No, using the reset button won't reset the IP address unless the "ip reset' button is turned on.
Jesse Dennis
Engineer
INTP
Message 16 of 20
(3,753 Views)
Is it the function is same between shut off / on the CFP instead of using the reset button?
Message 17 of 20
(3,750 Views)
Hi Ikramic,
Functionally they should be same, were you having problems?
Jesse Dennis
Engineer
INTP
Message 18 of 20
(3,746 Views)
yes, because i've tried this step also at the begining when the problem happend. But the ready ligh still not light.
Technically it suppose to be light because the on / off the CFP is likely had to reboot the controller as you told.
Message 19 of 20
(3,739 Views)
Hi Ikramic,
If you continue to have problems you might want to check your power supply also.
Jesse Dennis
Engineer
INTP
Message 20 of 20
(3,737 Views)
