06-06-2010 06:43 PM
Solved! Go to Solution.
06-06-2010 08:46 PM
06-07-2010 06:03 AM
		06-07-2010
		11:35 AM
 - last edited on
		06-12-2024
		02:07 PM
 by
			Content Cleaner
Hi russell-p,
What version of the FieldPoint Driver did you install? For LabVIEW 2009, you'll need at least NI-FieldPoint 6.0.5. Also, make sure that LabVIEW 2009 support is included:
Double-check that the FieldPoint VIs exist at [LabVIEW 2009]\vi.lib\FieldPoint as well.
10-05-2010 04:49 PM
I cannot find these VIs either...can't find them in the functions palette or in the vi.lib location......but I can see that the Fieldpoint 6.0.5 is installed in MAX
10-05-2010 07:47 PM
Did you install the Fieldpoint drivers after installing LV 2009?
10-06-2010 06:44 AM - edited 10-06-2010 06:48 AM
Depending on version of LV, palettes in LV may be context sensitive. Try creating a project and add a fieldpoint target to the project. Right click on the FP Target in your project and select new >>vi. Now the FP functions should show up
08-05-2013 11:53 PM
How to add a fieldpoint to the project? I dont have a fieldpoint connected to my PC.
08-07-2013 08:12 AM
Hi Yang,
Could you please post this is as a new forum topic?
