FieldPoint Family
changing fieldpoint settings programmatically?
is there a way to change the channel settings from inside a running RT program? E.g. changing the gain of an input channel or switching from voltage to current input?
So far I only see the option to configure the channels with MAX and once this config is downloaded it seems to be "static".
Thanks!
Bef
-DB
(6,835 Views)
Yes you can!  See here .
(6,832 Views)
Hi Bef.  Yes, there is a way to do what you are asking.  Check out on the palette Measurement I/O -> FieldPoint -> Advanced -> Ethernet Advanced -> Configure Attribute.vi (on my 8.5.1 setup).
I think not all attributes are supported, but maybe what you need is.
Matt
(6,829 Views)
Exactly what I was looking for. I didn't suspect these function in the "advanced ethernet" palette.
Thanks to both of you!
-DB
(6,826 Views)
