FieldPoint Family
configuring FP-TB-10
hi, I have an FP2000 with FP-TB-10, I am using  2 DI, 3DO and one analog input AI-5V , I am trying to configurate the new device, but when I click on Find Devices, the FP-TB-10 bank shows the module in the last slot as a DI, if I interchange any Digital module to the AI module the correct order is displayed, as soon as I change it back I have the same problem. I first thought it was a bad slot, but it reads the digital modules weither input or output !
(3,092 Views)
Hello G123,
Do you have another TB-10 to try this with?  I have not come across this behavior before and am curious.  Can you not use the configuration that is detected correctly?
Laura
(3,081 Views)
