FieldPoint Family
data acquisition using FP-1600 was interfered
I am developing a CVI 6.0 -based system with devices: FP-1600, FP-TB-10 and FP-DI-DC. (under windows 98)
A asynchronous timer (rate : 10ms) is created for data acquisition, a UI timer (rate: 100ms) pass data from a thread-Safe queue and plot points to chart.
The problem is: While hit the a button to do other things (we have another chart with scroll bar and other axis adjustment feature) or drag the windows, the real time wave form was distorted during that moment. I suspect the FP server hold the obsolete data. Have any solution?
Attached the asynchronous timer function. I don?t think that using ?FP_Advise? is useful.
int CVICALLBACK ReadTimerCallback (int reserved, int theTimerId, int event, void *call
backData, int eventData1, int eventData2)
{ float val[2];
float *value;
IAStatus result;
SYSTEMTIME dummy,dummy2,dummy3;
if (event == EVENT_TIMER_TICK){
//read data from 2 FP module
result = FP_Read (FP_handle, IOhandle_V_rou, current_V_rou, 20, &dummy);
result = FP_Read (FP_handle, IOhandle_V_fin, current_V_fin, 20, &dummy2);
//send data to queue
CmtWriteTSQData (g_dataQueueHd2, val, 2, 0,NULL);
(3,287 Views)
This really sounds like a video card problem. To test this theory, display your chart, and have an array that you can dispay in numeric form on your front panel. Scroll through the array data and verify that the points on the chart corrospond to the numerics. If not, then it is a video card problem.
To fix this, change the accelleration on your video card settings.
If you have any further problems, you may wish to contact NI directly.
Bryce
(3,287 Views)
