FieldPoint Family
how to programmatically read/write the range of a fieldpoint AI channel using LV
Is there a way to programmatically read/write the range of a fieldpoint AI channel using LV ? The example on NI site only permit you to have the name of the device and channels, not the actual set of the range of measure. Anybody has a VI (LV5.1 please)to share?
Thank you very much
(3,237 Views)
If you are using the FieldPoint VI's (Open, Create Tag, Read, Write, Advise), you do not have the ability to change the range of a channel. If you have a FP-1000 or FP-1001, you can use the Optomux commands as described in the FP-1000/1001 Programmers Reference Manual (FieldPoint Optomux VI's are available at ftp://ftp.ni.com/support/fieldpoint/LVFPOpto/ ).
Alternatively, if you have an ethernet network module and LabVIEW 6i or later, you can use the ethernet configuration VI's that ship with FieldPoint Explorer 3.0.1.
Aaron
LabVIEW Champion, CLA, CPI
(3,237 Views)
