FieldPoint Family
deploy asp.net web application built with National Instrument class without installing measurement studio
Dear Sir,
My web application  uses following name spaces
using NationalInstruments.UI;
using NationalInstruments.NetworkVariable;
using NationalInstruments.NetworkVariable.WebForms;
 I have Mesurement Studio 8.5 along with LabView installed while i was developing in VS2005. I want to deploy the application in a new pc where Measurement Studio is not installed. I tryed but when i browse the default.aspx,  a blank page is show. Is it possible to deploy the web application with out installing Measurement Studio and if yes, how?
 Thank you,
Mamunur Rashid
Software Engineer,
TechnoVista Limited
(6,337 Views)
Does this have anything to do with Fieldpoint?  Probably not since a fieldpoint system wouldn't be able to handle .net applications.  You should post this question in the Measurement Studio forum.
(6,326 Views)
