FieldPoint Family
zero values from NetworkVariableReader and cFP 2120
Hi! I've developed a software that uses a "NetworkVariableReader<double>"
bound to cFP-2120's FP\1AI\00 chan. If I read values with my app, often a 0
value occurs which doesn't when MAX is up and running on background.
I've already opened a ticket to Italian support with Reference#807012.
Thank you.
(6,097 Views)
if no other forum user had experienced you same problem or had used NetworkVariableReader successfully with FieldPoint, I suggest you to speak directly with NI Technical Support to further debug your problem.
Bye
(6,074 Views)
