hello rainer,
you could use a VI, which creates an TCP-listener on the server system on a free port. the FP-system sends the alarm message on this port to the target system. there a popup is generated and the program switches back to listen again.
the attached VI does this in basic functionality. additionally it hides it's window, so, that it isn't seen in the taskbar.
you must fit the error handling to your needs.
regards,
robert h
