FieldPoint Family
ftp access to D:\ (compact flash)
Hi, i would like to know if there is a way to reconfigure the ftp server on a cFP-2020.
At the moment the ftp server just allows anonymous access to the systemroot (C:\).
I have a 1Gb IBM Microdrive in the CF slot on which to store the data that is being logged. I wish to access this via FTP.
I would also like to set up user access on the ftp server, but this is of secondary concern.
Could someone please provide a solution.
Thanks in advance.
James
(4,293 Views)
Hi James,
It's Pete from NIUK Tech. Support department here. I have been looking into this problem for you. Unfortunetly I can't find any way to reconfigure the FTP server on a compact fieldpoint unit.
The only chance you have is to find an option in the NI-RT.ini file on your unit and change that. I have had a look in this file on our office fieldpoint unit and can't find such an option.
I have found a couple of links that you may find interesting if you haven't already seen them. I have pasted these below.
http://digital.ni.com/public.nsf/websearch/EF2C5AE37FE3672186256C3D005489A0?OpenDocument
http://zone.ni.com/devzone/conceptd.nsf/webmain/CE87CAF65D7DC07286256B4A006F9641?opendocument
Sorry I couldn't be more helpful. If you have any fur
ther questions regarding this issue, please do not hesitate to get in touch with me.
Peter H.
Applications Engineer.
National Instruments.
(4,293 Views)
James,
If I recall correctly, starting with LabVIEW 7.0, NI-FieldPoint 4.0, and the linked version of Measurement & Automation Explorer (3.0 I think), NI started including an FTP server with Measurement & Automation Explorer. The reason behind the inclusion was the fact that most FTP servers will not support multiple drives and NI needed a way to support it for the PXI-RT and FieldPoint-RT controllers. Personally, I have not used that FTP server, so I can not provide directions on using it.
Aaron
LabVIEW Champion, CLA, CPI
(4,293 Views)
Thanks to both of you for the info.
I cant find any options in the ini file either.
In fact i cant find any options for the ftp server anywhere at all.
It just seems to work by default.
Is it linked to the webserver or what?
I would like to find a way to limit or deny access, as a full rights anonymous ftp deamon is a security risk. But i still want to use the webserver.
Short of filtering out port 21 externally on a router, any ideas?
If i knew what software it was using it would help. IIS, apache or some other ni thing?
Regards
James
(4,293 Views)
With LabView 6.1 it really has worked. Now I Have updated the Software and have the same Problem.
(4,293 Views)
I thought i would answer my own question.
I discovered the answer by chance and thought others would like to know how it is done.
Connect to the fieldpoint ftp but add the drive letter, and a colon. eg.
ftp://192.168.0.1/d:/
this will display the compact flash in a cFP-2020
It has worked in all ftp programs i have tried (eg IE)
No need to use ni's ftp client.
ftp://192.168.0.1/c:/
also works but is the same as ftp root:
ftp://192.168.0.1/
Hope this helps someone else.
If anyone knows how to set up users and password permissions on the FP FTP i would still like to do that.
James
(4,293 Views)
