It seems like when you try to create the files using the executable, you get 0-byte sized files. Yet the total disk space available on the FP controller is reduced. What method are you using to write the files, LVM Write Express VI, Write Characters to File VI, etc? Also, how do you specify the path where the file is being created? Is it a valid path and do the empty files get created in the path you specify?
The FP-2015 has 512MB of non-volatile flash memory. Ensure that you have enough space available to begin with. Also make sure that you have the error cluster wired and handled properly.
The steps above will let us further troubleshoot your problem. Please let us know if you have any further questions. Thanks for choosing National Instruments.
A
Saha
Applications Engineer
Anu Saha
Academic Product Marketing Engineer
