FieldPoint Family
occasional corrupted analog values FP2010 LV DSC 6.1 Logos server v4.3.0.27
we built an application using LV DSC 6.1 and connected to an FP2010 module through the LAN. Sometimes, incorrect values are returned for analog inputs. It seems the values are wrongly associated with other tags. There's no obvious indication sent from the module to the DSC application to indicate the problem when it happens. There is no evidence of the bad status of the FP2010 (correct leds,no message). A software reboot of the FP 2010 using FieldPoint Explorer fixes the problem for a while.
The application is considered unreliable until this problem is solved.
(3,261 Views)
The first thing to do in this case is to upgrade your Logos version to the latest one, that you can download from :
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/c1a484551a75614686256ae300734336?OpenDocument
After upgrading it, verify if the behavior still persists.
Best Regards
Andre Oliveira
(3,261 Views)
