FieldPoint Family
stand-alone executables with DataSocket Server
How can I distribute an application that use datasocket server?
I need to install and configure the rights for datasocket server. Is it possible to include datasocket server and data socket server manager in my distribution kit?
Thank you,
paolo.
(4,182 Views)
Hellw Paolo
I do'nt think it is possible to include datasocket server in the distribution kit, but you can use datasockt server in stand alone opplication, if you install the datasockt server on the distribute PC.
First you have to enable this server on your application:
Using LV7, in the "Build Application or Shared Library" screen, choose the "Installer Setting" tab , mark "create installer", go to "Advanced...", mark "Labview Run-Time Engine", and "Datasocket Support".
Second, on the Distributed PC you have to install the Datasocket Server separetly, and Run it before you run your application.
Success !
Shimon
___________________
Try to take over the world!
(4,182 Views)
Hi, it is possible to add support for datasocket and datasocket server in your application installer, in this KB you'll find all informations needed.
http://digital.ni.com/public.nsf/websearch/3F8528E79FB62F92862567240064CCEE?OpenDocument
Regards.
NicolaC
(4,182 Views)
Thank you!
excellent link!
(4,182 Views)
