FieldPoint Family
to null the offset with fp-sg-140
Dear all
How can I null the signal offset of the fp-sg-140?
Is there a software method or an hardware ?
Thx
(3,025 Views)
As far as I can tell there is no offset nulling available for the FP-SG-140. You could easilly implement that by adding an external potentiometer to your bridge configuration or even use a VI to correct the offset value, but there seem not be a built in method, being it software or hardware.
I will double check on that and will get back to you
Regards
Andre Oliveira
(3,025 Views)
