FieldPoint Family
using field points how the dc voltage measurement is done?
i am new to labVIEW.. Using cFP-AI 100 i am trying to measure a dc voltage [5volts].. all the field point channels are configured on MAX. when the example VI provided runs with the proper i/o point is selected] there is error indicating that the connection is broken or network module is not pwered on.. but i have checked both .. What may be the problem?
(3,698 Views)
Hi ELUE,
Could you please let me know if the status LED (or any other LEDs are blinking) in a particular pattern on your fieldpoint controller? Also, could you please let me know what controller you are using and if you get a particular error code? Thanks!
Steven
(3,683 Views)
i have rebooted the FP items in MAX... and its working... thank you for sparing time...
(3,666 Views)
