FlexLogger
Change to Flex Logger Lite
I have a trial version of Flex Logger pro loaded, and I am setting up for 31 channels of data acquisition for a short term (~2 months) R&D effort. I think I should have used Flex Logger Lite. Are there any cautions I should be concerned about switching down?
(590 Views)
Accepted by speterson1
Installation is same for Lite and Pro version, only the activation of license decides what features are allowed. By default, when you install for the first time, it goes into full-featured mode i.e., Pro and at the end of trial it blocks you from any of the Pro features.
By your description, you don't need a Pro version and you can continue to use without any changes.
Santhosh
Soliton Technologies
(589 Views)
