FlexLogger
Configuration entries are sorted by name instead of order of creation
We developped a plugin that we sell on the NITN. The development started with R2 version of FL and finished with R3.
Today, a customer called because the plugin was 'hard to setup' because all the settings were 'mixed'.
We discovered that the configuration popup now has all its entries sorted by name !
Previously they were ordered by creation order.
Now the configuration popup is a mess and indeed difficult to understand !
Is this a bug or was it made on purpose ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,781 Views)
Accepted by CyGa
Its a bug, I'll see if I can get a fix put into the upcoming release
Kevin Fort
Principal Software Engineer
NI
(3,761 Views)
Thanks Kevin !
IMO, the best would be to let the plugin developers create this UI...
(3,750 Views)
Ya, that is coming at some point  (although not actively being worked on yet) 😀
Kevin Fort
NI
(3,742 Views)
Accepted by CyGa
Just confirming this is fixed in the upcoming release of FlexLogger.
Kevin Fort
NI
(3,669 Views)
Thank you Kevin !
Any idea on when is the new release coming ?
(3,663 Views)
The plan is that it should be available for download in December
Kevin Fort
NI
(3,659 Views)
